Waterline next to post hole
Old 06-03-20, 06:57 AM
I was digging for a post hole yesterday knowing that my waterline was close so I made sure to take it easy. You will see in the attached picture that I came very close to the waterline. My question is, how should I protect the line before pouring concrete into the hole or should I move the hole completely away from the waterline? I really like the location of the post so I would like to keep it there if possible.
Old 06-03-20, 07:22 AM
Received 408 Votes on 364 Posts
Welcome to the forums Shane!
Concrete shouldn't hurt the pvc although it might complicate things if you ever need to replace the water line.
Old 06-03-20, 09:14 AM
P
Received 913 Votes on 840 Posts
I'd cover the water line with something; scrap of tar paper, cardboard, piece of a tarp, rag... You can push nails through your scrap and into the dirt to hold it in place, set your post and pour your concrete. Since your water line is so close I would NOT use compacted gravel to fill the hole. I would use concrete.
Old 06-08-20, 06:34 AM
Thanks for the input everyone!
