redwood fence engineering
I'm building a 6 ft tall redwood fence. The fence boards are 5/8" thick. Because the fence is just a privacy fence between good neighbors and because it will be only 18 ft long I want to install just 3 fence posts – one on each end and one in the middle – then run 2 x 6 redwood rails between them. The posts will be 9 ft apart. Will I end up with sag? Many thanks.
Your fence sections should be 6 feet wide. 4 posts, 6 feet apart = 18 ft. Wind is another factor you aren't considering, and 4 posts will be stronger than 3. The posts need to be a minimum of 24" deep. Depending on your soil, up to 3 ft deep if its dry, sandy soil.
marksr
voted this post useful.
thanks
Thanks to you all. For the record, I've never seen a fence on 6' centers in this So Cal town. Of course, I don't get to the ritzier neighborhoods much. The redwood fence I built on 8' centers with 2 x 6" rails 22 years ago is solid as can be. Neighbor is not an issue since he doesn't give a $@&^%! about anything anyway. He's happy with the rotten fence in place now. BTW wind is not a factor since this is in a narrow space between garages.
Yea, most fence out here California land I've seen have posts between 7-8 feet to allow for 2X4X8 rails. Mine are on average 7.5' and they held up about 18 years with a good wind load. I've since replaced them w/steel posts same distance. I wouldn't go 9'. That's putting a lot of weight on the connection points, unless you rabbit and lag them in to the posts. What size posts are you going for? Would you run 2 or 3 rails?
