In ProcessAdSlots.php line 39: Trying to access array offset on value of type null
Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Fences, Posts, Railings and Gates
Reload this Page >
Can a cylindrical chain-link fence post “twist” out using a oversized vice
Old 09-25-20, 04:56 PM
Tried the water/2 x 4 method, tried the water/car jack method, tried the water/pick up method, chain-link fence post won’t budge. Does the concrete have enough of a “grip“ on the smooth metal to prevent it being able to be twisted out if I used a sledgehammer to whack an oversized vice grip clamped onto it?
I’m thinking about using a metal grinder to cut it out but I would want to have some thing covering the remaining stub since tires will be going over it
Old 09-25-20, 05:19 PM
Received 1,118 Votes on 1,038 Posts
Not sure what you're doing but... no.... a metal fence pole will not just "spin" out of the concrete.
Old 09-26-20, 04:47 AM
P
Received 632 Votes on 584 Posts
You've got two choices. Get a shovel and dig the post & concrete out of the ground. Or, dig down to the concrete and cut off the pipe, then cover it with dirt leaving the concrete buried in the ground.
Old 10-20-20, 10:32 PM
after trying the other methods shown online, I ended up taking Pilot Dane's advice as I noticed these poles were embedded within a huge amount of concrete
https://youtu.be/FNOKWWOvRq0
