Ideas to fill 10" H X 36"W gap in PVC chain link fence
My puppy found a 10"H X 36"W rectangular gap in my PVC chain link fence. It's at the back of the property so it's out of sight so I'd rather not replace the section. Would chicken wire or a hardware cloth (https://www.homedepot.com/p/YARDGARD...221B/202285853) be a sufficient substitute? I could zip tie it to the existing fencing but I am thinking it might be too flimsy.
If you fasten it well enough almost anything can be used to close the opening. If using wire ties get the black ones as they are more UV resistant and will last longer than the white ones.
I will need to cut the hardware mesh to fit the space. How would I protect the cut edges from the dog/kids? I suppose I could put the cut edge against the ground leaving the finish edge exposed.
