How to deal with old post concrete when replacing a fence
I had most of my side fence go down in a storm last summer, and finally had it replaced in December. The work was done by a local company that has an excellent reputation and I am very pleased with the new fence. The fence was not inexpensive, but it is stronger and better built I think, than the old one, so it should hold up for many many years. I will be replacing other old fencing in my yard, in the coming year or so, and was considering using this same person. But one thing this guy does, insists on, is to NOT pull up the old post concrete. He says that to do so leaves the ground unstable for the new post.
But plenty of other people do this, don't they?? I mean, you just pour new concrete in the same hole. That is what I and the BF did when replacing posts last year. This guy cuts the post off level, and places the new post next to it. This was fine on the section that he replaced, but one of the sections I want to redo next year has the existing gate post right next to my side garage door. And that is where I want it. He is saying that he would have to put the new post behind the old one since he does not pull up the old concrete.
Is there any logic in this or is this just a guy that doesn't like the extra work involved?
I think it depends. Yes, you really can not remove the old concrete without disturbing the surrounding soil. If you were to dig out all the loose soil so the new concrete had firm, virgin soil to bear against it would be good. But I think most people leave the loose soil in place which will make any new pour less stable.
Oh I have dug up the concrete before. It is certainly more work, but I was questioning whether or not it was the norm to NOT do it. I had never heard of this before. Thanks for your response!
Originally Posted by yardnut
Cutting the post saves the fence installer the extra work of removing the posts and disposing of all that concrete.
Originally Posted by XSleeper
Pour water around the post. Rock the post back and forth to loosen it up. Wrap the tow chain around the base of the post. Put the hook over the 'pin' of the bumper jack.
Lay 2x4s on the ground so they're NOT on top of the concrete and set the base of the bumper jack on the 2x4s.
Jack the post out of the ground. Repeat.
"so easy a child can do it" https://youtu.be/fS0TD4GaEvM
That is a different story, for sure. But none of mine are rotted or broken off, or have that much concrete so that would not be the case. When the time comes, I will probably pull up the one by the garage - I want my fence to end at that same place - behind that concrete would mean a foot back. I'll do it myself.
Not to hijack this post but I've thought of renting a concrete chainsaw ($150/day) and doing some cuts to remove the old concrete. Hitting the old (aged/solid) concrete with a sledge will definitely do very little to the fence posts I've encountered. Just worried that the chain/blade hitting the dirt might be bad.
As long as you something to grab on to you can use the old tire trick and maybe a lawn tractor or even the car if you can maneuver it close enough.
But to answer your original question, removing the old concrete is not typical. It's best not add concrete at all if possible. But soil conditions and how far you can sink the post will determine that.
