Repairing/sealing cracked landscaping ties used for a wall
Those 6" railroad tie walls that 3 years ago I replaced the top row, they all now have cracks in them 1/8" - 1/4" wide. In total about 40' of cracks. It is not cracking based on the holes drilled and the spikes were driven into. It's like the stress from drying in the sun I guess. I'd like to fill the cracks up in a meaningful way to stop the water from prematurely rotting out the ties.
I tried using the liquid driveway crack repair, even heated the container up first to make sure it would flow more easily, that did not flow in the cracks at all. Am thinking of using phenoseal perhaps? Or maybe carefully pouring in left-over driveway sealer that I have?
Once dried, I would paint over it with the existing paint that I have. Any suggestions?
Hi Beelzebob,
All ties old and new were originally pressure treated wood. All were painted with outdoor paint on the surfaces that were visible after installed. That is it. Yep, strange..
Dave
I changed the title as you have landscaping ties..... not railroad ties.
I don't think there's any way to seal/stop the wood from checking.
The gaps should open and close based on escaping moisture.
The lumber they use for those large ties is kiln dried but rarely is it 100%.
The inside stays wet for a long time.
These cracks stay open and seem not to get smaller or larger. I have not closely examined them or measured the width of the cracks over time but look at them frequently. OK I am going to have to figure out something to do. The cracks are quite a disappointment with all the money I spent a few years ago to get and put in these ties.
Hopefully.someone can lead me in the right direction. I am am looking for double bypass gate hardware to build a vinyl gate on my porch to block steps. The opening is 8.5’, but the wall it would be hinged on is 5.5’, so it needs to slide into itself. I would build it he panels to match the existing railing. I currently have an accordion gate tthat is hinged on the wall that I extend across. Does this hardware exist? If so, any suggestions for source? ThanksRead More
Have what I think is a wrought or cast iron railing outside of my home. Can the chips be cleaned up with some rustoleum or other product, or is it time to replace?
It was here when we bought the house 7 years ago and I assume it was there for many years before. I like the old-school railing style because it aligns with the traditional brick row home I live in.
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_2035_af956fc7a141d3f85d519d901986c3a911793887.jpeg[/img]
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_2034_97c3b8b1d249ff7b84afcec1d1acbae35da04737.jpeg[/img]
Read More
