Crossman 760 pump air rifle
I have a Crossman 760 air rifle which years ago had a lot of power and now barely even shoots a bb.Is there anything I can do to bring it back to life?
The "O" rings are possibly dry. Try opening the pump arm and you should see part of the pumping piston with several black rings. Put a drop or two of very light oil on each and then try pumping it. If that doesn't cure the problem, you may need to get an "O" ring kit. They should be available on line and elsewhere. The 760 was a very popular air rifle.
