Browning auto b2000
Old 12-27-05, 09:03 AM
dlewis
Browning auto b2000
My Browning auto 12 Gauge won't eject any shells. I have tried all diferent loads and have had no luck I also replaced some of the parts that were worn or missing when I got the used gun but it never has ejected properly. they either hang up or don't come out at all. any help would be appreciated.
Old 01-09-06, 12:23 PM
P
Is the B2000 gas operated?
Old 03-14-06, 01:28 PM
dlewis
I,m not sure How do you tell ?
Old 03-14-06, 01:48 PM
F
Received 1 Upvote on 1 Post
Old 03-15-06, 05:03 AM
P
Download that manual that flopshot provided the link for.
My Remingtons have gas ports which you can see in the barrel about half way down the length. Once and awhile they won't eject low base loads. I remove the barrel and lube the outside of the piston mechanism with Dryslide and that usually fixes the problem. You also could have a bad extractor (the thing that grips the rim of the shell and pulls it out of the barrel) or ejector (the thing that tosses the shell out). Do the shells flip out OK when you unload the gun?
