What does a slug do to a choke?
Old 07-16-06, 06:22 AM
W
WFO
WFO is offline
I just got a Remington 870 and the question came up. Will a slug ruin a full choke? If you're going to shoot slugs, what kind of choke should you use?
Old 07-16-06, 07:03 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
Shotgun chokes are made to produce a smaller pattern of pellets. I would not use a choke on a gun firing slugs. You may want to try an Improved Cylinder for slugs. Good luck.
Heres a link that may interest you.
http://en.wikipedia.org/wiki/Shotgun...use_with_slugs
Old 07-16-06, 07:13 AM
mattison's Avatar
That's about the most common shotgun out there and a very good one at that. You can pick up a slug barrel at just about any sporting goods store or even a used one at a gunshop or out of the paper.
Old 07-17-06, 07:03 AM
chokes
Barrels can be bought on ebay fro decent prices, if you have a pawnshop locally you can check there too. Slug barrels are very handy to have. You will have to decide if you want a rifled slug barrel or a smooth barrel. I use a mossberg 500 with a smooth barrel and winchester rifled slugs and get great accuracy up to 100 yards.
Old 07-21-06, 07:04 AM
Get a improved cylinder choke tube for slugs. They can be bought for around $20 new in my area. If your going to get serious about deer hunting look at a slug barrel with rifling. Cost will be in the $120-$200 range depending if you go with smooth bore, rifled, scope mount, etc... I have a Rem 870, 11-87, and a Mossberg 500 and own a slug barrel for all three as well as a field barrel.....
