Math equasion
Math equasion
Can any one tell me how high I should be hitting if I site my shotgun with sabot rounds in at 25 rounds. I am using the copper bonded hollow pionts, I can't seem to figure out the equasion. (-.2 at 25) (0 at 50), (-2.9 at 100) I want to be zero at 100. I have only shot at an indoor range at 25 yards. I am hitting to 4 to 5 inches high currently every time. Does this sounds about right for a hundred yard shot. I don't have excess to a 100 yards range.
have you tried to look up the ballistics for your ammo alot of companys will put ballistic information for their ammo which should give you the drop or rise of the bullet at different yardages.
while it can probably be calculated you would have to know velocity and bullet weight.
if your using a regular shotgun with slugs in it probably wont be very accurate and would limit your shots to 50 yards or less, while the rifled barrels with target sights can still have decent accuracy out to 100 yards.
