Winchester Model 100
Received 0 Votes
I'am trying to remove the stock for refinishing but i can't get it seperated from the barrel. HELP It is 308 winchester model 100 semi with 3 shot clip. I had all the screws off that i could find but it still would not come apart. The gun is probably 30+ years old. Hope you can help me out..THANKS
Received 0 Votes
Win 100 action removal
remove forearm screw from barrel extension,
pull op handle to rear and hold it.
Rotate barrel up and back (the op rod needs to be back to seperate from stock).
Make two 5/16 diameter by .73" long slave pin to push out the two pins visible in the lower receiver.
This will allow the removal trigger assembly.
Received 0 Votes
