Mossberg 535 front swivel stud
Old 04-08-08, 09:37 AM
H
I bought an Uncle Mike's swivel for my new 535 but when I installed the front swivel stud that came with the gun, I noticed the stud hole is 90 degrees off with respect to the swivel.
Removing the washer on the stud didn't help as it moved about 180 degrees from it's previous position.
The stud is already sitting at the base so it can't go lower. The threaded post is very short so adding another washer might not give it a good hold.
Any suggestions? Take it up with Mossberg?
Thanks.
Old 04-08-08, 10:52 AM
Take it up with good old Uncle MIke...........OK
Old 04-09-08, 09:31 AM
H
Went to Mossberg
I went to Mossberg with my problem because the stud came with the gun. They will mail me a new stud but if I still get the same problem, the magazine cap is the culprit. That would suck since that part is attached to the barrel with a locking washer.
Old 04-09-08, 12:44 PM
I can't help you on this one.........
when I ran to a problem like this I made a new part on my
Lathe & milling machine combo & threaded the part
Good Luck....................
