Which choke?
Which choke?
i just bought a mossberg 500 with a smooth barrel and was wondering which choke you use with the rifled slugs? i also bought winchester rifled slugs when i bought it but don't want to fire it with the wrong choke in.
boneyard....if you read the prior posts...the best would be a cylinder bore or rifled barrel. Either that or at a max...an improved cylinder choke. If yours are interchangeable..it's easy.
Welcome to the Forums.
Hello
The best choke for slug is a rifled choke, you can get one at any good sporting goods store. Shoot Sabot slugs, we hit the bottom of pop cans at close to 100 yards with a scoped shotgun. For regular rifled slugs shoot with a cylinder bore tube or Improved cylinder, they won't be as accurate as Sabots with a rifled tube, you'll have a rough time getting five shots on a paper plate at 75 yards.
Be safe
DF
Be safe
DF
