6mm Remington Ammo
6mm Remington Ammo
Is the 105 grain bullet for the 6mm Remington available only for handloading? I can't find any factory loads over 100 grains.
Are you trying to locate 105 grain bullets or are you trying to find factory ammo with bullets over 100 grains?
I don't know about Remington but Hornady and Sierra make bullets heavier than 100 grains.
Grady, I think you're right, 100-gr is the max, and I think that was by design, for the reason that Pilot Dane already has noted. The standard factory barrel twist for the 6mm Rem is 1:9, which they only ever intended to support bullets of up to 100-gr.
If you do find something heavier than 100-grains, you might check the bullet manufacturer's recommended minimum twist. And if they don't have a recommendation, check JBM's online stability calculator. Note also that Bryan Litz published some test results last spring showing you don't get the full measure of a bullet's ballistic coefficient if your stability factor (SG) is less than 1.5, so if you're thinking of shooting at longer ranges, and especially if you'll be shooting in a colder climate, "merely" stable might not be stable enough.
