white residue on brick
Old 10-20-02, 09:24 PM
Steve34
My basement brick fireplace has a fine white crystaline powder around the base. When I moved in the first thing I had to do was go up and gunk the top of the chase so I beleve there was some water damage inside. Anyone have an idea how to take it off?
Old 10-21-02, 04:31 AM
T
Received 1 Upvote on 1 Post
Removing efflorescence on brick
These mineral salts leached from the brick due to your moisture problem. Removal maybe as simple as brushing off. Most mineral salts are water soluble. A mixture of white vinegar and water may be effective. There are commercial brick cleaners available. If your moisture problem has not be corrected, the salts will tend to reoccur.
