Fireplace Surface Sealer
Old 11-21-02, 11:28 PM
j_husek
I am using a High Gloss Finish Surface Sealer made by Miracle Sealants Co. which was recommended at Home Depot.
I used it to shine up the bricks around the fireplace, but can I use it on the bricks inside as well? It is a wood burner that I am converting to gas. Will the sealer be able to withstand the heat or is their a risk of toxic fumes?
Old 11-23-02, 03:33 PM
T
Received 1 Upvote on 1 Post
Sealing brick fireplace
Do not seal bricks in interior of fireplace with brick sealer. If you have a need to paint interior of fireplace, there are special heat resistant paints available.
Have your chimney cleaned and inspected by a licensed chimney specialist before converting your fireplace. Check with local building inspector regarding permits and inspections for your project.
