Gas Fireplace question
Old 01-14-03, 06:53 PM
I have recently moved into a house that has a Heat-n-glow fireplace, (natural Gas). It is a remote control model and I believe about 10 years old. My question is this- originally, when the remote was pressed, the fire would almost immediately start. Now it is taking sometimes over a minute to ignite, is this normal? if not what can you recommend? Obviously I am using fresh batteries in the remote.
Old 01-14-03, 07:52 PM
Doug Aleshire's Avatar
stnaxe,
Best advice, call the manufacturer or send them an e-mail - be specific with your unit information. Here is the link;
http://www.heatnglo.com/contact/
Good Luck!
Old 01-15-03, 05:06 AM
fewalt's Avatar
Have you also put fresh batteries in the receiver?
If the switch is electronically triggered the logs should ignite in a second: there may be something wrong with the valve in the ignitor.
fred
