Fireplace Wall
Old 01-14-04, 11:00 AM
newhomeownerbs
Fireplace Wall
I notice that the back wall of my fireplace is 'bubbling' inward. I don't think it is the actual brick, as there is some black piece in the back of the fireplace.
Any ideas on the cause of this? Does this need to be fixed? How?
Thanks
Old 01-16-04, 07:52 AM
newhomeownerbs
As I look closer, I now see that there is some sort of Metal insert bolted into the fireplace. It is this insert that is "bubbling" - I assume from the prior owner making some really hot fires.
Question is: Is this something that needs to be replaced? What is the danger (if there is one)?
Thanks
Old 01-17-04, 05:38 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Question fireplace
Its not the damper or parts of it is it? ED
Old 01-17-04, 06:02 PM
webrebel's Avatar
This don't sound good to me. That sounds like a creosote buildup. When was the last time you cleaned the fireplace and flue???? You should have this done once a year at least.
Old 01-20-04, 04:59 PM
Ed Imeduc's Avatar
Have you hit on it, is it steel or not???? ED
Old 01-21-04, 06:34 AM
newhomeownerbs
I don't think it is steel - seems to be some kind of a metal insert. Black metal on 3 sides containing the fire, and it is "bolted" in.
Old 01-22-04, 04:12 PM
Ed Imeduc's Avatar
metal on 3 sides?? Is the whole firebox like metal??? do you have what is called a heatilator in there? do you see any bricks in there? ED
