hearth remodeling
Old 11-24-00, 02:08 PM
Guest
Post
I want to get of the brick hearth and replace it with ceramic tile. What is the best way to get the bricks removed without damaging my floor or wall?
Old 12-18-00, 07:24 PM
some help
Hello
This is a good way to change the look of your fire place.
I used Marble and it worked well--.now how I did it was not to remove the brick but used the brick for the base for the marble, install the edges first and then the top, if you do the face of the fire place install the sides then the face
keep all the tile lines going in the same direction with each other start in the center and work both ways..
