Chimney FIRE...now what?
Just get a professional Chimney Sweep in. They'll tell you what needs to be done.
to find one see: http://www.chimneyworks.co.uk/
HTH
HTH
Received 0 Votes
If I were you I'd contact your local fire department. They may check it out for you rather than risk having you call them later this winter. Or they can refer you to someone who can do the inspection also.
I would go with a chimney pro, many fire departments will not inspect chimneys. Make sure you tell him there was a fire, if it was not extinguished properly (too much water) the liners may have cracked.
