Design Question: installing a mantel shelf above an off-level fireplace
Old 08-29-05, 08:09 PM
A
I'm in the middle of refacing a gas fireplace. The original simply had fieldstone floor to ceiling surrounding the firebox. I demoed the stone, built a raised hearth which I tiled with slate, and am now planning to install a mantel shelf and tile the surround.
Problem is the top of the firebox (and frame) is not level. Across a 5' span, it's off by nearly a 1/2 inch. Would it be better for the shelf to be parallel to the firebox or for it to be level? I assumed it would be more important for the shelf to be level since there would be items placed on it, but if I were to split the difference and make it 1/4 inch off level, it would still hold items and would be closer to parallel with the firebox.
Any thoughts? Thanks.
Here are the before and after photos:
http://mysite.verizon.net/~craigslis...lacebefore.JPG
http://mysite.verizon.net/~craigslis...ireplace16.JPG
Old 09-03-05, 06:38 AM
T
Would you hang a painting "off-level" to match the box? Probably not... Same for the mantle. Hang it level - two wrongs don't make a right. If it's high enough above the firebox, the difference won't be too noticeable - and your collectible baseball collection won't roll off of it....
