Gas Stove
Old 02-18-06, 03:56 AM
Gas Stove
I want to install a free standing natural gas stove in my basement and direct vent through a basement window I wll have a lisenced plumber do the gas hook up. Any ideas or suggestion would be appreciated. Thanks
Old 02-18-06, 09:48 AM
jasper_60103's Avatar
seacilian:
I had a free standing natural gas stove installed with my basement project. It has only been a few months and I just love it. It keeps the basement very comfortable.
I can't say I heard of a DV through a window? My DV is going thru a wall. I can't give you any DIY tips. The dealer installed mine. I think its a good idea for the plumber to run the gas line and pressure test for you. Also, you may want to get a good strong helper for the install because that stoves a beast.
Did you choose the stove yet?
-jasper
Old 02-18-06, 11:04 AM
No stove choice yet but this project is a little ways off I am in the process of doing new oak kitchen cabinets from Home Depot once that job is done my finished basement,if I have any money left will get that gas stove. What kind did you put in? P.S. I plan on closing up the window I want to DV through.
Old 02-19-06, 07:18 PM
Ok, that makes sense.
I went with Heat-N-Glo Tiara II. Again, it does a great job heating the space. I only use it when needed, and it heats up the space in about 20mins. My basement is divided into a rec area, bedroom and shower bath. The finished area measures about a 1000 sq ft.
You can put the stove in later if short on cash. I would just have the gas line run. Also, you should have a pro survey your location of the DV to ensure it complies with codes. Good Luck.
-jasper
Old 02-22-06, 03:50 PM
According to my town code the vent must be at least 18 inches above grade so I have to snorkel up with a 36 Inch snorkel and it should be fine. Thanks for the comments.
