Installing a fireplace
Hi!
I was looking for some information about installing a fireplace in a room that doesn't have a fireplace. Can it even be done? How about a gas stove?
I have a room now that has never had a fireplace or anything of that sort & wanted to install one. Could this be done? How much do you think it would cost?
Thanks so much!
NiNa
Moderator note: Removed advertising website.
Thanks so much!
NiNa
Fireplaces and gas stoves can be installed in most houses. It depends on how much you want to spend. A built-in will run around $2000 by the time you buy the actual unit and accessories you need such as chimney pipe and the surround. You can also get free-standing fireplaces such as Franklin stoves. Still not cheap. They also make vented and ventless gas stoves. Good luck.
