chimney cleaning
Received 0 Votes
chimney cleaning
I am trying to decide if I need to do any chimney cleaning. From what I understand it is the creosote buildup that is a fire hazard. I took a look up the chimney from inside the fireplace with a powerful flashlight and did not see ANY shiny residue (that is the creosote correct?). Just some soot on the sides of the chimney, but it didn't seem like a lot. Should be OK then correct?
Thanks in advance
Thanks in advance
Received 0 Votes
Thanks for the advice. All the wood I burn is split and 3 years seasoned, so maybe that is why it is so clean. I do try to avoid burning "green" wood, mainly because it just doesn't burn well.
