pellet stove question
Received 0 Votes
I am buyinga house with a pellet stove and have a few questions.......how hot does it get above and behind??...I want to create a mantle of sorts above it....and also redo the wall behind it (currently brick)......another one too.....it is postioned off-center!...can I reposition it?? it has a straight conx to the vent...will Ihave to pull it out a bit and put in an angle pipe to the vent or does it have to stay as is?? Thanks!!
robby1824,
What you can and cannot do with changes to your stove will be found in the manufacturers specs and your local codes.
These things are approved under specific installation requirements.
