Replace or Modify Gas Starter in wood Fireplace
Received 0 Votes
I have a wood burning firplace with a gas starter embedded into the center of the brick bed. It's round, steel, with a steel metal cap that just sits on the top of embedded and suken mixing area. There is a center gas feed, and the gas is mixed and dispersed by the top around the round sunken mixing area, through little slits. Gas flow is controlled by a valve already built into the firplace wall. I want to get the starter out and tap into the pipe that feeds it, so I can install gas logs. Does ANYONE know who makes this embedded starter, and how to get it out?
