Removing stainless steel flexible chimney liner
I have been cheated by a chimney sweep who sold me a 7" flexible (uninsulated) stainless steel chimney liner when I didn't need one (smoky basement problem solved by capping adjacent flue from unused basement fireplace) and now I want to take it out. This has been confirmed by consultations with certified chimney repair professionals.
What steps do I need to consider besides breaking out the parging cement at the top of the chimney and at the bottom where it meets the smoke chamber and then pushing& pulling it down through the fireplace?
Is this method possible or does it have to pulled out from above?
The 7" liner was ovalized to fit into a 9x13 tile. The length is about 30-35'
Would I have to re-cement anything at the top?
Can the stainless liner be sold for much as scrap or to another homeowner ?
I have worked on rooftops and would be taking many safety precautions given the demanding physical movements need for the job.
Thanks for you consideration
Leaving the liner in place has two problems as I see it:
a. The oval 7" liner reduces the dimension of the 9 x 13 tile flue which reduces the potential draft and I need as much as possible.
b. The liner isn't insulated which I have been told is not recommended if not against code
My feeling is that the effort it will cost me or the $200 I pay to somone to remove is worth the improvement to the draft, not to mention possible hazard. But I would be happy to get up there and do some work to be able to pull it out.
