Do you think this Fireplace works?
Received 0 Votes
I bought this house last year without speaking to the owner. So, I'm not sure if this fireplace ever worked or if it was just for decoration. Many repairs and updates were done in a generic fashion within this house...so who knows.
Anyway, please take a look at this pictures and let me know what you know. http://usera.imagecave.com/elliottno...replace006.jpg
http://usera.imagecave.com/elliottno...replace003.jpg
What type is this? What parts are missing? I don't smell any gas when I turn the red nob. And there is a lever in the basement that I think is for this gas line (but I can't follow it completely). But I don't smell gas when I turn that either.
I don't know anything about these type of fireplaces. The vent is above (5 inch square hole) and bends. There are no other levers or on/off switches or tags to read.
Let me know what you think.
Received 0 Votes
I believe I can get gas to this unit. There is a pipe there and I assume I can get gas to the fireplace.
With the Gas Logs...I still need a base unit that will light....right? Or does a base crate with igniter come included when you buy gas logs?
Or should I get a gas fireplace insert instead?
Received 0 Votes
Received 0 Votes
Get a pro in there. First, remove that old unlisted piece of junk. Have a Level II inspection. Make repairs as needed. Then, if ok, install listed vented logs with a safety pilot. There should be an accessible shutoff within 6 ft. of the fireplace. While the IFGC allows it inside the firebox, only if so listed and none are listed for direct flame contact. This shutoff is too high.
For a hearth pro, go to www.nficertified.com and for a certified fireplace inspector, go to www.f-i-r-e-service.com
HTH,
Hearthman
HTH,
Hearthman
