Replacing Wood FP and Log Lighter W/Vent Free
I need advice on this. My mom has at long last decided to get away from wood. She has a vented FP. The vents are inside the room, I think. Should they be closed? I'll likely remove the doors so they don't get closed accidently. I haven't looked at the damper but it should close even after many years, I hope. She has a tall vaulted ceiling and ceiling fan. 34,000btu should heat as well as wood.
There is a large log lighter so I don't expect a problem with gas supply. I'll also do a BTU survey. 2psi systems are popular here so I expect a regulator just for the FP. The pressure will need testing as well. Any suggestions for CO alarms? Any other advice?
