Pellet stove & baseboard heater
Old 11-01-08, 09:22 AM
T
Hi,
I'm having a pellet stove installed and I'm being told that I need to move the baseboard heater that is behind where the stove is to be placed. I trust my installer, but just wanted to verify that it is necessary to take this additional step. Any insight would be greatly appreciated!
Thank you,
Carissa
Old 11-02-08, 05:44 PM
V
Originally Posted by tmcintire View Post
Hi,
Thank you,
Carissa
No, you should not need to move your baseboard heat. Mine was professionally installed and it was not a problem. Mine is pellet stove is not in a corner though.
Old 11-04-08, 03:36 AM
T
Thank you for your input. It really helps to have more information. Thanks again!
Old 11-04-08, 03:50 AM
GregH's Avatar
Super Moderator
Received 67 Upvotes on 61 Posts
If you "trust your installer" you would do well to ask them for the reason for moving the baseboard rather than making any comments about it first.
Codes vary greatly in different areas and there could be a good reason.
In case you don't know home insurance policies require that wood burning installations need to be specially noted on policies for your policy to remain in force.
The insurance companies normally will inspect the installation
