Fireplace Glass Door
Old 03-25-09, 11:56 AM
Talking Fireplace Glass Door
Hi,
I have a fireplace with an opening of 39.5" W & 21.5" H. This fireplace is all painted cinder block from the floor to the ceiling. My wife and I like the clean look of glass doors instead of a screen. However, we were looking at some glass doors from Pleasant Hearth and our opening won't fit any of their 3 sizes (small, medium, large). Does any one know if there are glass doors that will fit my opening that won't cost an arm and a leg?
Thanks,
sweetboy
Old 03-27-09, 03:49 PM
Tolyn Ironhand's Avatar
Received 595 Votes on 511 Posts
If you have a Home Depot near you check there. I bought some doors last year about this time on clearance for about $100 (50% off) Mine is smaller than your opening but I don't remember if it was the largest size or there was one bigger. Good luck!
Old 03-30-09, 02:00 PM
W
you can get door that are a little bigger that are fasten by adjustable hooks to the inside lip of block it is pulled tight to the front and seals itself to the blocks
Old 04-01-09, 01:18 PM
Just a small update. I was at a local midwest home improvement store (Menard's) and saw the same type of doors I got at HD. The had a larger size then mine so you would be good to go.
Old 04-13-09, 08:59 AM
W
Fireplace Doors
WD Metalcraft
47 Bridge St E
Kitchener ON Can
519 579 1881
Sells direct to consumer, say your reselling the door
and recieve 25% discount.
