New mantle and surround
I have a fireplace in our condo that I'd like to add a wooden mantle and surround to, but I'm not sure I have the space to do it safely.
The opening of the fireplace is appx. 30"x30". It is located on the right side of a brick wall that is around 10'x12'. It is set up in this way because the condo on the other side of the wall also has a fireplace that shares the brick wall, and uses the other side for its opening.
On the right side of the wall, there is only around 8 inches of brick separating the opening of the fireplace and the end of the wall. Is this enough room to put, for example, a 4" wooden side panel, or would that be a fire hazard? If I can't do side pieces, do you have any other recommendations for dressing up this fireplace?
I was also wondering if you know anything about devices for fireplaces that help to push the heat out. I enjoy using our fireplace, but it doesn't do much to help heat the room, and I've heard that there are things that can be done to fix this.
Thanks!
Thanks!
Received 1 Upvote
1 Post
You should have no problem with a wooden surround. You can get kits that are fairly easy to install at a good fireplace accessory shop, as well as a blower-grate assembly selection. Look in Yellow Pages. You should be able to find what you want for both in one of those shops.
