Clean Woodstove Glass
I need to figure out how to clean the glass of my woodstove. It is starting to turn black. Any ideas?
I use a product called "Fire Brite Glass Cleaner" by Worcester Brush which I bought at Home Depot. It works great and it is non-abrasive and non-flammable. It does have the warning "DANGER Harmful or Fatal if Swallowed - May burn on contact - Causes eye/skin irriation". Use caution when applying and removing. I usually spread newspaper on the floor to catch any drips and use rubber gloves.
You spray it on, let it set for a few minutes then wipe it off....no scrubbing. Follow the directions and it should work great.
Good Luck
Good Luck
