Heatilator gas fireplace insert
Old 01-15-01, 12:35 PM
Guest
Cool
I have a heatilator gas fireplace insert. It is difficult to start, and occasionally goes out momentarily while lit. It occasionally goes out entirely, and I cannot start it back up. I have been informed that it requires a cleaning. Does anyone know what is involved, with a cleaning, and what is the procedure? Thanks!
Old 01-18-01, 10:32 PM
some help
Hello
This is not some thing you should do as a generic cleaning.
Need the name, model no. size and any other information you have on the unit, Then will see what we can do to help you with the problem...
Old 01-20-01, 07:28 AM
Guest
Heatilator fireplace insert
Heatilator insert model GNDC33NAT. I'm pretty good at DIY around the house and on cars. I'm sure I could save myself the $200 they want to clean this thing. As long as I had some procedure or guidlines.
Thanks!
Old 01-22-01, 01:42 PM
some help
Hello.
I found only one site that I think you can get some information on Good Luck ttp://www.firesidecorner.com/products.html
Old 01-22-01, 06:56 PM
Torch
I had the same problem with another brand, but the fix may be the same. Turn off the gas and use a Q-tip with rubbing alcohol to clean the oriface (where the gas out). When you look into the oriface, there should be a small pin sized hole. In my case, there was a tiny spider inside that blocked the hole just enough to let it work sometimes but not others. You may also need to check the thermocouple if the rest of the unit is clean and it won't stay lit. Good Luck.
