Painted Fireplace Help!
Old 01-25-01, 10:18 PM
Guest
Lightbulb
If anyone has some suggestions I would much appriciate it. This is not a gas fireplace. This fireplace was originally red brick with the hard texture, and has been painted white. The fireplace has red tile bench style seat in front but facing room is more hard textured Now WHITE PAINTED BRICK! The brick fireplace goes up to the ceiling and down to the floor with the bench seat I mentioned. Is there a way to repaint with brick paint to make this worth looking at? Also can the texture be smoothed out? Trying to do this on newlywed finances and retiling seems way to out of price range!
Old 02-26-01, 12:27 AM
some help
Hello
You have a great chance to make a great looking wall out of the white brick.....Faux paint them any way you want it works it looks great and you can do it yourself check this out...Good Luckhttp://www.aceoftrades.homestead.com/sponging.html
Old 03-05-01, 05:27 PM
hy
brickfireplaced
Why not consider stripping the brick and bringing it back to the original, Suggest you use PEEL AWAY 7 which will remove the paint easily for you
