Any reasons to prefer Millivolt over Intermitent Pilot Light fire place?
Old 11-14-12, 12:17 PM
G
For a gas fireplace is there any reason to prefer Milli-volt over Intermittent Pilot Light (IPI) fire place?
Old 11-14-12, 12:37 PM
B
Welp, you don't need any power or low voltage nearby to run it since the pilot light flame touching the pilot generator provides the DC millivolt current to run the system.
Old 11-14-12, 01:09 PM
G
I didn't realize that IPI systems needed a power cord. A milli volt system might be useful in a power outage. Thanks for that tip.
Old 11-14-12, 01:20 PM
B
the old millivolt systems were 250 MV DC
the ones now a days are 750MV DC which is .75V DC (3/4) of a volt
so, if you go that route, solder all the connections
any loose or corroded connections render no heat
i think this is what you're referring to
http://kozyheat.virtual.vps-host.net...ges/IPIsys.pdf
Old 11-16-12, 05:46 PM
Mike1555's Avatar
I know that some IPI's have a battery option that can be used in the event of a power outage
Old 11-16-12, 06:02 PM
Received 1,525 Votes on 1,408 Posts
A battery option ? I've never seen one of those.
