Detail for stove pipe penetration through concrete wall
Old 01-25-13, 09:52 AM
K
Would anyone happen to have a Detail for stove pipe/chimney penetration through concrete wall. Mostly need to know if there is any fire stopping that would need to be done.
Thanks,
Kari
Old 01-25-13, 10:01 AM
chandler's Avatar
Received 7 Votes on 6 Posts
Welcome to the forums! Last check concrete didn't burn readily Just kidding. Is the wall concrete block or poured monolith? You will be using triple wall pipe anyway, so heat won't be a problem. The triple wall will insulate the hot pipe from the outside and the third wall will be for your make up air for combustion. Do you have a stove in mind, brand ?? Wood burner, pellet, gas, etc??
