woodstove
Old 02-10-01, 03:52 PM
Guest
Question
I'm installing a custom barrel stove in my garage and need to know what would be best for a fire wall behind the stove. Would fire resistant sheet rock do if there's air space between the resistant sheet rock and the pine planks used to face the wall?
Old 02-10-01, 04:47 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
I believe that I would use an insulated, metal reflective-surfaced floor panel that is designed to go under indoor stoves, rather than sheetrock. Airspace is a good idea.
Sheetrock is fire-resistant because the gypsum in it retards fire, but it is still covered with paper.
Check at a Home Center or fireplace store.
Good Luck!
