wood fired stove connecting to oil fired boiler pipework
Old 09-19-13, 03:08 AM
A
Hi everyone.
is it possible to connect pipework from a wood fired back boiler directly to an oil fired boilerīs existing pipework? We already have a wood fire insert and would like to replace it with one with a back boiler. local plumbers have quoted around 7,000 thousand dollars for work I donīt see any reason to have.
Thank you for any advice
anthrenus
Old 09-19-13, 11:58 PM
Received 1,505 Votes on 1,393 Posts
Welcome to the forums.
I'm guessing your boiler is defective and you are asking if you can use a wood fired boiler to replace it.
I don't see why not ... but ... not being sure of the climate where you are in Spain...... can the wood fired boiler deliver enough heat for your application ?
