smoking fireplace
My fireplace, original on a fifty year old house, seems to be drafting poorly, and dumping alot of smoke into the house. There are no obstructions in the flue and all the dimensions seem to be correct. The house is one story, so there is no stack effect. I suspect the culprit is the original terra cotta caps. They are unusual in appearance, but show no signs of failure. Any help would be much appreciated
Received 1 Upvote
1 Post
If the house has been remodeled and tightened up, you may have to equalize the fireplace room pressure by cracking open a window.
Try that, and see if that doesn't solve the problem.
Good Luck!
Good Luck!
Flue Draw
had a problem with that kinda back-draft a few years back..I actually went to some "home improvement" catalog and bought a cap that "aero-dynamically" creates a suction on flue..I was skeptical..but it was a cheaper first shor that having a person make the chimmeny taller (big $$$) for a better draft effect...bottom line it works..I was impressed...so you want to look for a chimmeny cap that as the wind blows by it helps draw a suction from the flue..I am sure you can search for it on the WEB...
