help reoving double wall vent pipe from fireplace
Old 09-22-13, 07:16 PM
N
I am installing a 36" wood burning fireplace. I installed the 1st 36" double wall section. I then realized that I need to install the 30 deg. offset & return 1st. I was able to seperate the outer pipe, but cannot figure out how to seperate the stainless steel inner pipe. I can rotate the pipe, but I can't get it to seperate from the top of the fireplace. Any suggestions?
Thanks
Mike
Old 09-24-13, 06:34 AM
N
Ok, so I got it finally. Phoned a friend in the construction business. Basically took 3-4 screwdrivers to simultaneously pry the little retaining tabs back so it will release.
