Question about control mechanisms for gas fireplace.
Old 10-17-13, 12:49 PM
Hello,
I recently purchased a home with a freestanding natural gas fireplace. Unfortunate the control device/pilot do not work. It appears to be a very obscure brand from Europe and I cannot find anyone who can service it.
I'm hoping that it would be possible to install a simple manually lit system, but every stove contractor refuses to do something like that because it would mean tampering with the UL listed control. I assume they just don't want to have the liability.
Is there any reason I couldn't simply remove the control system, pilot and what not and install a valve that could just be controlled by hand.
something along the lines of:
3/4" pipe comes out of wall, emergency ball valve for shut off, pipe to ball valve for fireplace control, pipe into burner.
That way i could just turn on the gas and light it with a match and call it good. Obviously i would have to be careful to shut off all the valves when not in use, and it wouldn't be used unattended.
Talking to contractors makes me feel like this is a bad idea, but is it?
I plan on replacing this thing with a good gas insert so i hate to spend a ton of money on it. Just looking for the simplest solution to get some heat and get through this winter.
Old 10-17-13, 11:00 PM
Received 1,523 Votes on 1,406 Posts
Welcome to the forums.
Everyone wants a temporary fix to get thru this season..... and then it's next season.
Darn right !!! We're talking about gas here. I can't not make any recommendations to you other than changing out the stove.
Old 10-18-13, 08:56 AM
PJmax,
Thanks for the welcome.
I understand the concern. All liabilities aside, for which you have none. Why would my method not be possible?
I understand the concern, normally you have a mechanism to prevent gas from leaking when a flame is not burning (thermocouple / & pilot ). But I would have redundant shut offs (ball coming in and control) and would not use it accept when in the room. Isn't that how gas fireplaces used to operate anyway?
