Speaker wire beside gas line
Old 12-17-13, 10:53 AM
I have 2 gas lines that run to my basement and upstairs gas fireplaces. Then run right beside each other as the 2 fireplaces are essentially right on top of one another in the house. I am going to be wiring up a home theatre system downstairs and will be running some speaker wire through the ceiling. The easiest way is to run it along the existing gas lines.
Is this safe to do? Can speaker wire be along in parallel to a gas line?
I know that speaker wire has voltage running through it, so I am unsure what the code is for such a scenario. Thanks for any help.
Old 12-17-13, 11:08 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
No problem. The signals on speaker wires won't be a issue.
