8x8 clay liner question
Old 01-04-14, 04:42 PM
Z
Hello-
What is the inner flue dimensions to a standard 8x8 clay liner?
(I assume its not 64")
And how does that pertain to something called the '7x rule'? and if a water heater heater can be vented into it.....
Old 01-05-14, 04:05 AM
Received 672 Votes on 595 Posts
Is anything else using this chimney? You aren't allowed to use one flue for multiple vents.
I'm not sure I understand the rest of the question Unless I'm mistaken the clay flue liner in my chimney is 7" square. I'm not sure if that's a nominal size or actual exterior or interior dimension.
Old 01-05-14, 04:21 AM
Z
An 8x8 clay liner would have a smaller inner flue dimension. Probably 7x7 or even 6.5x6.5... im not sure which.
Theres a rule of thumb called the 7x rule and I am not sure how the inner dimension of that liner would calculate with a water heater.
As far as multiple vents using the same chimney, although this is not the case in my situation, I would say the majority of 80 percent or less furnaces share a chimney with a water heater so I am not sure what you mean about not being able to use multiple vents with one chimney/flue.
Regardless, my original questions remain.... thank you.
Old 01-05-14, 04:25 AM
Locally the list them as 7x7 liners as they typically fit in either chimney block that has an 8x8 void in the middle or other block/brick laid to the same dimensions.
I probably didn't explain well You can have multiple flues in one chimney but you can only exhaust one device per flue.
