Fireplace insert install
Old 08-26-14, 10:17 PM
Hello,
I have an fireplace insert I purchased off of craigslist, and the previous owner included the stainless steel liner, plus a bunch of stove pipe. I am installing into an existing brick chimney. I believe the previous owner also had a brick chimney this was installed in. I don't plan on doing the install myself, so maybe this is the wrong website to be on, but...
I had a contractor over to give me a quote for install, and he said that the stove pipe was unnecessary in a brick chimney - that only the stainless steel liner was necessary.
Who is right? What is the purpose of ever installing the liner inside the stove pipe?
Thanks!
Old 09-01-14, 11:22 AM
Mark_MS's Avatar
What brand fireplace insert is it?? You can find the manual for most brands via google the manual will state exactly what is required. A liner only does not sound right to me.
I have stainless going up my chimney 3 inch, most stoves require 3 inch or 4 inch depending on height needed to clear chimney and altitude.
Old 09-01-14, 11:31 AM
Received 1,505 Votes on 1,393 Posts
I replied to this on 8/27/14 at 1:44AM but the post is missing ?
What does the installation manual for the insert recommend ?
If you don't have that information - post the make and model and we could check on it.
Basically an echo of Mark's. Thanks for posting Mark
My insert uses a 4" concentric stainless stovepipe that goes thru the brick chimney to a cap up top.
Old 09-01-14, 12:59 PM
Mark_MS's Avatar
I didn't delete your post!!
Old 09-01-14, 01:03 PM
Mark_MS's Avatar
It occurred to me that I am quoting pipe dimensions for a pellet stove insert and not a wood insert, which requires a minimum of 6 inch pipe.
If OP would tell us what he has would be great!
