How to connect gas fireplace igniter wires
Old 11-15-14, 12:29 PM
B
I have a Lennox Elite Series gas log fireplace. I could not get it to light at the start of the season. I took the face plate off underneath and found the two wires for the igniter were not hooked up. I am not sure what they go to. 2 wires, one white and one black. I see the TPTH, TP and TH....there is one connection peg open on the TP for one of the two wires to slip on.... Not sure what to do.
Old 11-16-14, 10:18 AM
Received 1,531 Votes on 1,414 Posts
Welcome to the forums.
This was a working insert and sometime over the summer the wires became disconnected ?
The wiring on the gas valve is not the igniter wiring.
There should be two wires from the pilot generator and two more wires from a thermostat, if used, connected to the valve. The pushbutton igniter should only have one wire on it.
Old 11-21-14, 06:09 PM
SeattlePioneer's Avatar
TP= Thermopilot = pilot generator
TH= Thermostat
So the two wires from the pilot generator should be connected to the TP terminals and the two wires to the thermostat connected to the TH terminals.
