Can I remove flue ?
Old 02-22-15, 12:05 PM
O
Can I remove flue ?
I live in a mobile home that has a central heating/air conditioning unit installed in a closet, all electric. directly on top of this unit is some type of flue /vent. it is not connected to anything as far as I can tell and I none of my appliances uses gas/fuel, its all electric. can I remove this flue? its a source for air entry and I don't want it.
Old 02-22-15, 01:30 PM
Received 1,510 Votes on 1,397 Posts
Welcome to the forums.
As long as nothing is connected to it there should be no reason why it can't be removed or capped off.
Old 02-22-15, 02:38 PM
Received 404 Votes on 360 Posts
I assume the MH used to have a gas furnace ??
It's not a big deal to remove it but you do need to be diligent when covering the hole so it doesn't leak. I'd cut a piece of sheet metal a few inches larger than the hole, apply a bead or two of caulk around the hole [under the sheet metal] screw it down and then tar over the perimeter.
