Thermopile question
Old 10-14-15, 11:48 AM
R
Thermopile question
My Thermoplie ( GNDC30 ) is outputting .250 V, does anyone know if this is enough to allow the ROBERTSHAW MODEL 7000 GAS VALVE to operate?
Separated from..... http://www.doityourself.com/forum/fi...or-gndc30.html
Old 10-14-15, 05:10 PM
F
Received 36 Votes on 28 Posts
Welcome, Rick to the best DIY forum on the Internet.
It is always best to start a new thread for a new problem rather than "piggy backing" onto an existing thread, even if the problem is similar. Hopefully a moderator will do this concerning your problem.
Your Thermopile should output 750 millivolts so you are outputting only a third of the proper output. It is unlikely that low of a voltage will properly operate your gas valve. Like the thermocouple problem it is often a matter of a dirty pilot burner not having a sufficient flame AND fully engulfing the Thermopile that is the real problem.
Old 10-14-15, 07:49 PM
Received 1,530 Votes on 1,413 Posts
I see Furd welcomed you aboard. I started a new thread for you.
Although the specs. show it needs at least 100mv to open the valve.... the pilot generator circuit usually generates voltages well above that. A weak pilot is the biggest cause of low output voltage.
I'm trying to locate the Heatilator specs.
Old 10-15-15, 05:48 AM
R
Thanks guys, took the glass out, what a dirty mess, here's the pilot, what do you think. Name:  Holiday-1.jpg
Cleaned the pilot assy, got the voltage up to 280 mV, unit will now light...
2 hours later the voltage droped to 245 mV, unit will not fire up, I'm thinking replace the Thermopile...
