Does anyone know what this hole is for?
Old 01-17-17, 02:32 PM
A
Does anyone know the purpose for this hole in the side of the wood-burning fireplace in my basement? Is there a way I can cover it? I'd like to prevent my cat from being able to jump inside. Thanks!Name:  File_000 (2).jpg
Old 01-17-17, 02:39 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! How old is the house. It is possible it is a cool (not fresh) air intake for a blower. Where does it go? Can you shine a light in it to see?
Old 01-17-17, 02:52 PM
Received 850 Upvotes on 746 Posts
Is that the only hole or vent? Does it turn after going in so far?
Old 01-17-17, 02:55 PM
A
From what I can see looking straight back, there's just a brick wall (so I'm guessing a side of the fireplace). The house was built in 1950, and we have a gas fireplace above it on the next level sharing the chimney.
Old 01-17-17, 02:59 PM
Can you reach in there and tell if it turns or just stops? You could use a coat hanger [or whatever] if you don't feel comfortable sticking your arm in there.
Old 01-17-17, 04:15 PM
chandler's Avatar
IF you are using this fireplace as a wood burner, it can't share the same flue with the one above it. Are you certain there aren't two flues? Big safety hazard if not.
Old 01-19-17, 04:49 AM
A
it is only the depth of the fireplace as far as I can tell... it's on an interior wall, so it doesn't lead to outside or anything. There's a closed off pipe on the other side of the wall, so I'm wondering if maybe it was a compartment for ashes or some such. hoping i can fashion some sort of screen for it, because it seems like most ash dump doors are for square or rectangular openings.
Old 01-19-17, 08:02 AM
I wonder if it was some sort of system for circulating heat captured from the masonry. Most I've seen where above the firebox. I doubt there would be any issues if you blocked it off.
