Is this gap in my firebox normal? (Between bricks and damper casing)
Old 01-30-18, 01:19 PM
X
Received 1 Vote on 1 Post
Hi all,
I'm repairing my firebox (Novice DIY) and noticed that there's a gap between the damper casing and bricks just above the lintel. Is this normal? There's some insulation in the gap as well but no refractory cement.
I was reading an older article that said it was to allow for expansion when the casing gets hot. I have not seen anything else to confirm that, however.
Any ideas? Should I fill the gap with some refractory cement or leave it alone?
Thanks!
Old 01-30-18, 05:23 PM
Received 1,619 Votes on 1,491 Posts
I am not the pro here but something doesn't look right.
You have a space of 1/4"-1/2" where you can see regular house insulation ?
Originally I was thinking the insulation is not a fire stop but since it's contained within the brick firebox... it doesn't need to be. I would also think there would be a lot of air leakage thru the insulation.
If no one addresses this I'd want to get a chimney mason or chimney sweep in to check it out.
